Just wanted to confirm if the new Jetpack 5.0.2 is compatible with isaac_ros packages.
Our upcoming Isaac ROS DP1.1 release will add support for Jetpack 5.0.2. The available Isaac ROS DP release only supports Jetpack 5.0.1 DP.
Thank you for the quick reply.
Can you please provide the plan release date for Isaac DP1.1 release that will support Jetpack 5.0.2?
Thanks again.
That’s great. Thank you.
