Hi Team,
We are trying to boot AGX Orin SOM on our custom carrier board. but we are facing some issues with AGX Orin SOMs. We checked our carrier board, it is working fine with other AGX Orin SOMs.
We are using Jetpack 5.1.1 to flash the SOM. We tried flashing the SOM using “flash.sh” script provided by Nvidia and failed to flash.
I am attaching the error logfile FYR, please review it and help us to resolve.
FlashFailedLog.txt (70.9 KB)
Hi SeetharamNS,
Do you mean the issue is specific to one AGX Orin SOM?
[ 7.8098 ] ERROR: might be timeout in USB write.
Error: Return value 3
It seems you hit USB timeout issue during flash.
Please check if Q: I get a USB timeout error during flash Orin. How to resolve that? could help for your case.
Or you may try using another USB cable.
Tried flashing using different USB cables as well. Ended up with the same behaviour.
Team waiting for your reply.
Hi team,
Waiting for your valuable inputs.
Are you using standalone Ubuntu host PC to flash the board? Or something like WSL2, VM, docker?
Do you have the devkit to reproduce the issue on the devkit to clarify if the issue is specific to your custom board?
