Jetpack 5.1.2 - Jetson Orin NX - board J401/ J4012 - black screen
Hello
After I upgraded my Jetson to the jetpack 5.1.2 from the 5.1.1 (by command line) with the usual script, I got a black screen, and the Jetson loops (try to load the OS, bios, OS, Bios, OS) … The bios parameters seem ok. If someone has a workaround ? :-)
So, due to the issue (maybe linked to the Seedstudio board), I’ made a rollback to the 5.1.1 → OK
Remarks , no issue are raised in the log → When I flashed the jetson to the 5.1.2
Thanks for your support
Suggest to contact with Seeedstudio support first. Thanks
I contacted SeeedStudio → Still waiting an answer
I grabbed the console log today : → DCE issue, It seems the board is not ready to support all jetpacks upgrades :-(
[ 17.371417] CPU:0, Error: dce-fabric@0xde00000, irq=28
[ 17.376719] **************************************
[ 17.381649] CPU:0, Error:dce-fabric, Errmon:2
[ 17.386140] Error Code : SLAVE_ERR
[ 17.390003] Overflow : Multiple SLAVE_ERR
[ 17.394486]
[ 17.396017] Error Code : SLAVE_ERR
[ 17.399877] MASTER_ID : DCE
[ 17.403108] Address : 0x2212000
[ 17.406703] Cache : 0x1 – Bufferable
[ 17.411008] Protection : 0x3 – Privileged, Non-Secure, Data Access
[ 17.417822] Access_Type : Read
[ 17.421310] Access_ID : 0x0
[ 17.421313] Fabric : dce-fabric
[ 17.428121] Slave_Id : 0x3b
[ 17.431343] Burst_length : 0x0
[ 17.434838] Burst_type : 0x1
[ 17.438163] Beat_size : 0x2
[ 17.441393] VQC : 0x0
[ 17.444174] GRPSEC : 0x3f
[ 17.447229] FALCONSEC : 0x0
It has been resolved here.
L4T 35.4.1 on Seedstudio Orin NX - Jetson & Embedded Systems / Jetson Orin NX - NVIDIA Developer Forums
I have tested and worked well with JP5.1.2
Thank you !
