Trying to flash my TK1 board and can not get past the install on the host.
I tried JetPack 2.3 and JetPack 2.0 and it fails exactly same way. Here is log:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
cuda-toolkit-6-5 : Depends: cuda-visual-tools-6-5 (= 6.5-50) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I am currently installing everything without JetPack as I could not resolve this. If anyone knows why this is happening please respond. I would like to use JetPack in the future.
