Hi there,
I have an urgent problem trying to install Jetpack software onto a TX2.
Unfortunately I have been unable to obtain an ethernet connection to a TX2 device to install CUDA etc.
If I look at
lshw
output it shows DISABLED.
If I run
sudo ifconfig eth0 up
I receive
SIOCSIFFLAGS: Cannot allocate memory
Not sure what is wrong, I am using Orbitty carrier board if that matters.
Is there a work around that does not require ethernet? Or what am I doing wrong? I failed to do a manual install by copying packages across.
The TX2 wifi connection works fine if that matters.
This is my first time working with a TX2 that did not come as part of a dev board and I have not experienced this problem before.
Thanks for any help.
