— 🤖 This is an automated AI response. I’m here to help, but please verify important details! —
To mass flash Jetpack 7.2 to AGX Orin, you can try the following steps:
Make sure you are using the correct command to create the mfi pack. The command you provided seems to be incorrect. Please refer to the documentation for the correct command.
Check the error message you provided. It seems that the directory /tmp/ /initrd/usr/share/misc/ already exists. You can try to delete this directory and then run the command again.
If the above steps do not work, you can try to use the --massflash option with the l4t_initrd_flash.sh script. This option allows you to specify the number of devices to flash.
