We have custom carrier board for jetson AGX Xavier industrial module. We have Type-C connector, USB2.0 Lines connected to USB1 and USB3.1 lines are connected to UPHY_TX6 lines. I also have PD controller only to provide 5V power to the Type-C Connector (external world). We configured PD Controller in DRP mode. when we connected mobile to the Type-C connector (board) there we are able to detect my mobile (able to transfer files and able to charge the mobile also)
but when we connected to Type C ) to PC through Type-c to type-A cable then Jetson is not detecting. For jetson to detect in PC do we need change any configuration in Jeston. Can any one help on this? Please find the schematics
Jetson_AGX_Xavier_usb.pdf (162.2 KB)
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
Issue is not resolved yet, please help
You can read the document first.
Can you please specify on which document you are pointing?
You can also specify which release you want to use.
We are using NVIDIA Jetson Linux 35.2.1 version.
