We have sourced a third party carrier board with a Jetson AGX Xavier Module that only has a Micro-USB port for configuration and two display ports (Instead of HDMI). I have been able to put the board into recovery mode and successfully flash the Module with Jetpack 4.4 DP LINUX FOR JETSON AGX XAVIER. The problem is there is no output to the display ports when i reset the device to get to the User configuration screen, and there is not USB-C port to access. The micro-usb shows up on my host computer in lsusb as:
Bus 001 Device 019: ID 0955:7019 NVidia Corp.
and dmesg shows it connected as:
[ 5675.072952] usb 1-1: new high-speed USB device number 19 using xhci_hcd
[ 5675.221664] usb 1-1: New USB device found, idVendor=0955, idProduct=7019
[ 5675.221671] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5675.221675] usb 1-1: Product: APX
[ 5675.221679] usb 1-1: Manufacturer: NVIDIA Corp.
My question is, does the jetpack software automatically detect what ports the Carrier board has and configures them appropriately or do I need to get a custom configuration file from the Manufacture to enable displayports?
Is there another way to access the user configuration screen not via screen?
