My Jetson Nano 2 GB Developer Kit which has 945-13541-0000-000 serial number, is burned out. I was trying to use Jetson nano from GPIO Pin, and i gave 5V volt from my ASUS 350 Watt power supply. In Developer Kit’s carrier board, i am seeing only U9 Component burned out.
Could you please tell me what is the U9 compenent?
Where can i find U9 component?
May i replace it with new U9 component?
Also, if it not possible to replace the component via soldering, May i buy new carrier board (without Jetson Nano Module)?
Sincerely,
İbrahim
