So I messed up with my 5V4A Jack power supply (gave higher voltage or wrong terminals, I do not remember), But immedietly noticed the U58 regulator smoke up. From then on powering Jetson Nano devkit is not possible (either through 5V4A jack or microUSB port 2A) both does not work. So my DevKit is just lying around and my heart is broken.
I have attached macro pictures of U58 & surrounding parts.
Is there any way to make the carrier board work ?
Will the compute module still work or is it also damaged ?
please let me know/ help Jetson community & moderatorsā¦
So I removed the U58 block, Iām not sure if its correctly removed.
Also during the process I think I damaged/removed nearby components.
I can notice the nearby components missing also. Circled in red. Will it have any impact ?
I have attached the pictures, please have a look.
Still its not powering through microUSB 5V2A.
I just want to point out that usually a carrier board power issue does not harm the module itself. Youād need a different board support package if you used an alternative carrier board, but the module is probably still good once on another carrier board (dev kit carrier boards are not sold separately).
