Jetson Nano 2 GB Power Consumption
My goal is to monitor power consumption on the Jetson Nano 2 GB version. Is it possible to do this with built-in tools? I have seen online that this does not seem to be possible with commands like tegrastats, unlike the Nano 4 GB version and other Jetson embedded devices. Is this true? If this is the case, is there any workaround?
Thank you.
Hi, no sw way to get the power consumption since no power monitor on module as others. You can use a DC supply to observe the input current and calculate the power.
