Problem is basically the title. My Jetson Nano 2GB only boots 50% of the time.
I’ve come to this number by attempting to boot about 50 times so it’s a definite trend.
The behavior is the same across all of my power supplies:
USB-C connected to lab power supply at 5V and 5.2V (capable of up to 10A)
USB-C connected to 5V 3A UBEC from a Lipo battery
GPIO on 5V and GND
I have also experienced this behavior on 2 different 2GB Jetson Nano boards, and have tried two different flashed SD cards.
The green power light is always solid green, so it isn’t indicative of when the Jetson has booted or not. I have to be plugged into a screen via HDMI to actually know.
This is pretty frustrating because I want to run the Jetson Nano headless but I never know when the Jetson Nano actually boots.
We can’t reproduce this issue with JP-4.6 on Nano-2GB.
Could you try to connect uart log to check if device isn’t booting, the uart print any log or not.
You can connect TX/RX/GND cable on J12 pins to check debug uart log.
Please reference detail from user guide.
