I RMA’d my jetson as it failed on the ethernet for no reason, we did a swap out and the replacement worked fine for 2 days and again the ethernet failed.
|Case|:|89037|
|RMA|:|65095111101|
I am curious to know if this is a batch failure of some sort or is there a bug and a way to update some firmware to resolve the ethernet controller from failing.
Sorry for bringing this trouble.
Please do the RMA again, and provide the RMA number for your case.
I will inform our internal team to check this problem.
