Jetson Nano Camera Design
I recently purchased a carrier board from Aetina.
I need to connect my 15 pin CSI camera to 36 pin CSI port in the carrier board.
(Although the board does have a 15 pin port, I’m using two cameras. Therefore, I need to figure out how to connect 15 pin camera to 36 pin port)
On page 9 of the datasheet, it provides a pin map diagram of the 36 pin port.
For the camera, I checked this datasheet.
I come up with this diagram, but couldn’t figure out to which port connect POWER_EN.
According to Nvidia’s camera design,PWDN means Camera Power-Down GPIO.
So, should I connect it to 5V? or ground?
Any help will be appreciated!
It looks like so, but you might need to check with Aetina, also should note the signal polarity.
