Hi everyone,
i am using jetson orin nano with Seeed Studio J401 reComputer Carrier and csi camera imx477.
i am use to be gpio pins (jetsons 40 pins on board) pin number 3,5,8 (output pins), then i set pin number 7 is input pin. ( in 40pins on jetson board. ).
gpio pin number 7 pin doesnt work correctly (in jetson gpio pins), others output pins are working. number 7 is input pin it get have a signal from sensor.
if i try camera connect with usb no problem camera is working and all gpio pins is working.
but if i try use camera with csi cable
i have a questions :
1-Does the csi camera pins have a connection to jetson’s pins?
2-while work, csi cable camera delaying 2 second get a photo. why?
3-i want use csi cable camera and i want use some jetson gpio pins for input and output. is it problem jetson nano pins 3,5,7,8 for csi camera?
Thank you and Regards
***Edited
