I am having a module called MT7915AN(Mediatek) which is wifi module connected to Jetson Nano board with M.2 key E using M.2 key to Mini PCIe adapter. When I checked it with the lspci -v command it doesn’t show up the device is connected. I have attached the dmesg log there it shows pcie - 0 link is down, retrying and end up with ignoring. Also attached pci log (dmesg | grep pcie). I am using barrel jack power supply of 5V 4A. The module MT7915AN requires 3.3V voltage and 3.5A current.
1.Is Jetson nano carrier board is able to provide this much of current when USB keyboard, mouse and hdmi are attached?
2.Do I need to modify dts and dtsi to add node/subnode?
M.2 Key-E slot provides power to the connected device. Are you saying that the Mediatek card that you are using here needs an external power supply and hence you are connecting the power externally?
BTW, are you sure about the 3.5A current? that looks a bit high.
Hi vidyas,
I am not connecting an external power supply. Is carrier board able to provide this much of current? is there any way to supply the power externally? And yes the requirement is 2.5 A to 3.0 A and 3.5 is maximum.
Hello, We are using Leetop carrier board A203. We connected MT7915 wifi module to M.2 key E slot. The SOM board we are using is p3448 180-13448-DAAA-B01. When we fire a command lspci in terminal, it doesn’t show any pcie device connected to the board. When checked in dmesg. It says pcie link is down.
