Jetson Orin Nano dev kit.When flashing the latest JetPack R38, the system shows EFI messages then freezes.
Boot log (HDMI output):
EFI stub: Booting Linux Kernel…
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Measured initrd data into PCR 9
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services…
After that the screen stays frozen.No further output. No login prompt. No serial prompt.
If I flash JetPack R36, it boots normally.
Question:
How can I safely upgrade from R36 to R38?
Is there a required bootloader or QSPI update path between these releases, or known compatibility issue preventing R38 from booting on the Orin Nano?
