Hello.
Which driver to use for jetson tk1 from these versions
[url]Page Not Found | NVIDIA
If you are referring to drivers for the video hardware within the Jetson, then none of those. Those are for PCI devices, Jetson GPUs attach directly to the memory controller. If you have an added video card, then it becomes quite interesting…probably it’d just be a case of testing and seeing what works (starting with most recent).
For all Jetsons you’d use the L4T drivers.
Thank you for answer.
Regards
saux2017
If you do test one of those drivers with an add-on video card, do share the results! A lot of people would be interested.
Incidentally, does anyone know if NVIDIA has ever made a mini-PCIe video card of any kind…even if it was just a concept card?
