I have been using a Jetson TX1 for a few months with the persistent issue that when using a 4 cell lipo the Jetson requires pushing the power on button multiple times to get the Jetson to turn on. Once on, no problem. When hooked up to the 19V power supply also no problem. I am not sure if this is related to the Jetson not starting or if it is just capturing the input voltage as stated:
https://devtalk.nvidia.com/default/topic/938799/?comment=4890965
I have not used the Jetson for about 1 week and upon going back to it, the Jetson will not turn on at all. The lights don’t turn on and using the micro-usb to access it the Jetson is not recognized by my desktop, lsusb doesn’t recognize the Jetson is plugged in. I have tried the hard reset with no luck. I have tried powering the Jetson with both the 4 cell lipo and power supply (which I checked, and it is outputting 19v).
I am beginning to assume the Jetson is dead but would appreciate any help to get it back up or something else to check. Thanks.
