sudo apt-get install –y libmnl0 libmnl-dev
[sudo] password for tbuckley:
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package –y
tbuckley@BaseSystem_0_2:/usr/local/cuda-10.0/targets/aarch64-linux/lib$ sudo apt-get install libmnl0 libmnl-dev
libmnl0 is already the newest version (1.0.4-2).
libmnl0 set to manually installed.
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
cuda-toolkit-10-0 : Depends: cuda-documentation-10-0 (>= 10.0.326) but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p1 14G 14G 0 100% /
sdkmanager filled up disk space and left the system unusable,
Need help identifying what can be removed to free up disk space,
/usr$ mydu
618M ./src
23M ./sbin
1.3G ./share
109M ./include
282M ./bin
2.1G ./local
5.9G ./lib
628K ./games
11G .
shows /usr/local, /usr/share, and /usr/lib using gigs of disk space.
Terry
