Hi
I have followed a several posts here describing how to power the Jetson TX2 development board but still have no successful test. I wanted to ask if there are any exact specs for this.
I have looked at:
The battery options discussion and I checked to ensure that I am providing enough voltage and current, including for bootup: Battery options for TX1 SOM - Jetson TX1 - NVIDIA Developer Forums
This recommended guide on power supply for the TX2: https://developer.download.nvidia.com/assets/embedded/secure/jetson/TX2/docs/Jetson_TX1_TX2_Module_Battery_and_Charger_Design_Guidelines_v1.5.pdf?rMGvezpm-BFhCrCJxk5DQryMBwoDmqPrsHu0EGbOp9BBaax4jy0ZvqaD7_bhgXcTmUNOy42F6CDoc-BsoW16LVtcLS7IsH3d0rotYct1j7HEFyG9V9qsKx2kRVHJjnm_baqswGjOtOv2K3h50rLmfsVzKK2HHFdLX_H97NOBmcB_PIfEyCphUZazq_00MgIiZcCh_09YKnXpU_RseJ6By5RYn8-Aj4Guzr0 . I could not find any info about filtering caps here unfortunately.
These discussions, referencing up to 33000uF capacitance and an additional inductor as close to the barrel connector as possible. I am going to order some additional caps and inductors to mirror this setup, but would like some help understanding what the actual tolerances for the input voltage fluctuation are.
Jetson tx2 powered using battery - #3 by christopheraburns
Here is what I have tried:
- Initially tried to power it with a 14.4V & 22.6V (2/3 * 7.2V 5Ah lipos) setup connected to other components. Red power light is on but device does not boot up when I press the power button
- Tried to power it separately at 14.4V and 22.6V (3 * 7.2V 5Ah lipos). The result is the same. Red power light indicates that it’s receiving power, but the device does not boot up.
- I read in another discussion that you have to add filtering capacitors and I did. I tested up to 600uF Capacitance but saw no difference. I tried this both with other components connected (motor controller, some powered sensors) and also in an isolated setup with just the Jetson + the batteries. I’m ordering some caps and inductors but would appreciate some precise specs. I unfortunately do not have an oscilloscope I can access, but it seems like I might need one just identify the issue.
Strangely, Jetsonhacks has a video where he just plugs in a lipo battery source and a TK1 turns right on :o
Does anyone have any pointers here so I can work towards a reasonably predictable successful setup? What works? How much attenuation am I supposed to add? And should I expect similar issues once the robot is running? I have other loads such as 2 12V motors, another microcotroller and some sensors. Should I just run the Tx2 isolated from everything else?
Thanks for any advice. Happy to answer any questions if needed as well.
