I have creat new topic for post:
Continuing the discussion from Tx2 jetson_multimedia_api got capture timestamp?:
When I use single stream capture, the timestamp float sometimes. However,when i use four stream capture, It’s very obvious
03-24 11:23:45.594 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[0] last ts: 1365273914, current ts: 1365307298, delta: 33384
03-24 11:23:45.622 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[0] last ts: 1365307298, current ts: 1365340681, delta: 33383
03-24 11:23:45.625 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[1] last ts: 1365307298, current ts: 1365340681, delta: 33383
03-24 11:23:45.628 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[3] last ts: 1365307346, current ts: 1365340730, delta: 33384
03-24 11:23:45.628 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[2] last ts: 1365307298, current ts: 1365340681, delta: 33383
03-24 11:23:45.656 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[3] last ts: 1365340730, current ts: 1365374113, delta: 33383
03-24 11:23:45.658 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[1] last ts: 1365340681, current ts: 1365374065, delta: 33384
03-24 11:23:45.660 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[0] last ts: 1365340681, current ts: 1365374065, delta: 33384
03-24 11:23:45.661 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[2] last ts: 1365340681, current ts: 1365374065, delta: 33384
03-24 11:23:45.689 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[0] last ts: 1365374065, current ts: 1365407448, delta: 33383
03-24 11:23:45.691 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[3] last ts: 1365374113, current ts: 1365407497, delta: 33384
03-24 11:23:45.693 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[2] last ts: 1365374065, current ts: 1365407448, delta: 33383
03-24 11:23:45.695 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[1] last ts: 1365374065, current ts: 1365407448, delta: 33383
03-24 11:23:45.723 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[3] last ts: 1365407497, current ts: 1365440881, delta: 33384
03-24 11:23:45.724 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[2] last ts: 1365407448, current ts: 1365440832, delta: 33384
03-24 11:23:45.726 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[1] last ts: 1365407448, current ts: 1365440832, delta: 33384
03-24 11:23:45.727 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[0] last ts: 1365407448, current ts: 1365440833, delta: 33385
03-24 11:23:45.756 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[0] last ts: 1365440833, current ts: 1365474216, delta: 33383
03-24 11:23:45.758 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[2] last ts: 1365440832, current ts: 1365474216, delta: 33384
03-24 11:23:45.760 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[3] last ts: 1365440881, current ts: 1365474265, delta: 33384
03-24 11:23:45.761 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[1] last ts: 1365440832, current ts: 1365474216, delta: 33384
03-24 11:23:45.791 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[1] last ts: 1365474216, current ts: 1365507600, delta: 33384
03-24 11:23:45.792 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[2] last ts: 1365474216, current ts: 1365507600, delta: 33384
03-24 11:23:45.793 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[0] last ts: 1365474216, current ts: 1365507600, delta: 33384
03-24 11:23:45.795 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[3] last ts: 1365474265, current ts: 1365507648, delta: 33383
03-24 11:23:45.823 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[2] last ts: 1365507600, current ts: 1365540983, delta: 33383
03-24 11:23:45.825 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[0] last ts: 1365507600, current ts: 1365540983, delta: 33383
03-24 11:23:45.828 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[1] last ts: 1365507600, current ts: 1365540983, delta: 33383
03-24 11:23:45.828 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[3] last ts: 1365507648, current ts: 1365541032, delta: 33384
03-24 11:23:45.856 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[1] last ts: 1365540983, current ts: 1365574367, delta: 33384
03-24 11:23:45.858 D/MultiCamera(10928): [app/src/camera/MultiCamera.cpp:235] stream[2] last ts: 1365540983, current ts: 1365574367, delta: 33384
