I am trying to setup a Jetson xavier, I ran the installer script in the first boot as suggested. But after that the jetson went into a bootloop. I noticed that the Jetson got quite warm to the touch and even then the fans did not kick in. Please help me find a way to fix this.
This started happening even before trying to install jetpack, and then hoping that flashing with jetpack might help, i tried jetpack 4.1.1, the old one, that didnt help either. I then tried to flash the Jetson with only drivers, filesystem and os, but now i got the error like systemd was blocked for more than 120 seconds
I ran the install script first that came on the box initially, as suggested. After that the module went into a bootloop, thats when i tried to flash it with jetpack to try to get it to work as I mentioned before, with only filesystem os and drivers checked.
Yes the flashing did finish successfully
I am also noticing “cpu4: shutdown” logs while booting, is that normal?
Something even more wierd is I keep getting new errors with each reboot I ll share a screenshot of the error I just got now I haven’t seen this happen before
Sorry that we didn’t meet such error before. I would suggest you to remove the downloaded driver file and reflash it again.
Also, since you have entered the kernel and systemd is running up, I think you have done the work to create your username/pwd, language and keyboard setting, right?
Nope I have tried it a few times in the past week with no success, I keep getting into a bootloop. I am also assuming its a hardware issue. Thank for the help.
