Jetson xavier nx flashing mistakes
Hi:
Recently I used my host machine to flash my jetson xavier nx developer kit in order to give PPS support to jetson.
However, I followed the instruction from: Enabling PPS on Jetson Nano and then flash the kernel of Jetson, when I finished flashing. My Jetson could not boot. The log of flashing shows: The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
Besides. I flashed my machine with: Jetpack 5.0.1
Do you have any idea about that? Thx
This issue should be posted in the Jetson category so the support team has visibility. I will move it over for you.
Debugging will require the serial console boot log. This should work even if boot itself fails.
Thx for your quick reply!
When I turn on the Jetson and connected it with another Jeston and run the minicom then I got:
Do you know what is the problem? I could not boot any more after flashing… I used Jetpack 5.1…
Thx again…
Do you mean JetPack version 5.0.1? There is no available version 5.1 yet (and 5.0.1 is still considered a developer preview).
Btw, a full serial console log would be useful (I can’t personally help on A/B redundancy, but anyone who does will want the full boot log). When you have a screenshot it only shows a small part, but the same serial console app has the ability to save the entire boot to a log file, and you can upload the log file to this forum.
