JN30D Jetson Nano 128GB SSD (How to enable the built in SSD)
Dear Nvidia Dev forum/Support,
Product : JN30D-Nano-128GB SSD
I have successfully setup the Jetson nano including VNC for remote access.
The Nvidia SDK ecosystem is installed on running on 16GB microsSD card However I try to download example models “Jetson-inference” repo to run on the Jetson nano. I ran out of space which I found the repo was trying to install on the MicroSD card with limited space and I´m blocked to continue with my task.
So my question is,
I specifically bought this JN30D jetson nano 128GB SSD with the intension of running my own AI models on this SSD however I´m not able to enable that or not sure how to use this SSD partition which is in-built.
How to find out if my SSD partition is available on the jetson nano and how to use for my work on downloading and running AI models from this SSD partition.
https://auvidea.eu/download/D70878.pdf (This is product I purchased and using it for running AI models inference)
Pictures attached provides some info the available partition on the device.
Any help/support is highly appreciated and welcome.
Need urgent help as we are working on tight timelines to run custom AI models on this HW.
Thank you.
Br,
Raj
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Some clarification.
  1. This board is not NV devkit. It is a custom carrier board from other vendor. Please contact with them to report issue too.
  2. What is the result of “lspci” command?
