I am running isaac in a docker container, and have been happily using it by starting the simulation app manually using the --allow-root flag. I am now trying to transition to using jupyter to interact with the simulation, but running into problems.
How should jupyter be started when running on docker? What I tried is the following command executed inside the container:
root@xxxxxxxxx:/isaac-sim# ./jupyter_notebook.sh standalone_examples/notebooks/hello_world.ipynb --allow_root
This starts the jupyter kernel without any errors, and I am able to connect to it and execute cells in the notebook. When I try to execute the first cell, I get the following warning:
Omniverse Kit cannot be run as the root user without the --allow-root flag.
Running as root should not be necessary under most circumstances.
Doing this may cause kit to encounter errors when running as a normal user again.
followed by an Exception thrown by carb:
It seems that the allow-root flag gets lost somewhere along the way. Is this a known issue or am I doing something wrong?
