Keeping cardboard Box on the ground
Hello friends, i was trying to create Synthetic data for 3d detection of cardboard boxes. when i randomize, the bottom point of the box is going under the ground or pallet. It does not stay on the pallet or on the ground all the time. how can i fix this? Please help. Thanks in advance. Code is below
import omni.usd
import random
from pxr import Usd, UsdGeom, Gf, Sdf
import asyncio
Load your scene
output_dir = r"C:\Users\shaji\Downloads\output_data"
usd_path = r"C:\Users\shaji\Downloads\try.usd"
omni.usd.get_context().open_stage(usd_path)
def check_prim(path):
prim = stage.GetPrimAtPath(path)
if not prim.IsValid():
print(f"Error: Prim at path {path} is invalid.“)
else:
print(f"Prim at path {path} is valid.”)
return prim
Object references (box, lights, cameras)
box_prim_path = Sdf.Path(“/Cardbox_C1”)
box_prim = check_prim(box_prim_path)
dome_light_path = Sdf.Path(“/World/DomeLight”)
dome_light = check_prim(dome_light_path)
dist_light_path = Sdf.Path(“/World/DistantLight”)
dist_light = check_prim(dist_light_path)
camera_paths = [
Sdf.Path(“/Camera_01”), # north
Sdf.Path(“/Camera_02”), # east
Sdf.Path(“/Camera_03”), # west
Sdf.Path(“/Camera_04”), # south
Sdf.Path(“/Camera_05”) # top
cameras = [check_prim(path) for path in camera_paths]
def get_bounding_box(prim):
raise ValueError(f"Invalid prim: {prim.GetPath()}")
bbox_cache = UsdGeom.BBoxCache(Usd.TimeCode.Default(), [UsdGeom.Tokens.default_])
bbox = bbox_cache.ComputeWorldBound(prim)
return bbox
def get_bounding_box_center(prim):
bbox = get_bounding_box(prim)
center = bbox.GetRange().GetMidpoint()
print(f"Bounding box center for {prim.GetPath()} is {center}")
return center
def get_bounding_box_size(prim):
size = bbox.GetRange().GetSize()
print(f"Bounding box size for {prim.GetPath()} is {size}")
return size
def randomize_scene():
box_size = get_bounding_box_size(box_prim)
# Randomize box size keeping the typical logistic box ratio
scale_factor = random.uniform(0.5, 1.5)
scale_value = (scale_factor, scale_factor, scale_factor)
print(f"Scale value: {scale_value}")
# Randomize box orientation
rotation_x = random.uniform(-180, 180)
rotation_y = random.uniform(-180, 180)
rotation_z = random.uniform(-180, 180)
rotation_value = (rotation_x, rotation_y, rotation_z)
print(f"Rotation value: {rotation_value}")
# Apply new size and orientation to the box
rep.modify.pose(input_prims=box_prim, scale=scale_value, rotation=rotation_value)
# Randomize dome light
dome_light_intensity = random.uniform(500, 1500)
dome_light_temperature = random.uniform(3000, 6500)
print(f"Dome light - intensity: {dome_light_intensity}, temperature: {dome_light_temperature}")
rep.modify.attribute(name='inputs:intensity', value=dome_light_intensity, input_prims=dome_light)
rep.modify.attribute(name='inputs:temperature', value=dome_light_temperature, input_prims=dome_light)
# Randomize distant light
dist_light_intensity = random.uniform(2000, 4000)
dist_light_temperature = random.uniform(3000, 6500)
print(f"Distant light - intensity: {dist_light_intensity}, temperature: {dist_light_temperature}")
rep.modify.attribute(name='inputs:intensity', value=dist_light_intensity, input_prims=dist_light)
rep.modify.attribute(name='inputs:temperature', value=dist_light_temperature, input_prims=dist_light)
render_product_dict = {}
render_products =
for idx, camera_path in enumerate(camera_paths):
pos_name = f"camera_{idx+1}"
render_product = rep.create.render_product(camera_path, resolution=(1280, 720))
render_product_dict[pos_name] = render_product
render_products.append(render_product)
Create a basic writer
writer = rep.WriterRegistry.get(“BasicWriter”)
writer.initialize(output_dir=output_dir, rgb=True, bounding_box_2d_tight=True, bounding_box_2d_loose=True, bounding_box_3d=True, camera_params=True)
writer.attach(render_products)
Attach the necessary annotators
rep.AnnotatorRegistry.get_annotator(“bounding_box_2d_tight”).attach(render_products)
rep.AnnotatorRegistry.get_annotator(“bounding_box_2d_loose”).attach(render_products)
rep.AnnotatorRegistry.get_annotator(“bounding_box_3d”).attach(render_products)
rep.AnnotatorRegistry.get_annotator(“camera_params”).attach(render_products)
rep.AnnotatorRegistry.get_annotator(“DepthLinearized”).attach(render_products)
async def preview_scene(num_previews=1):
for _ in range(num_previews):
for pos_name, render_product in render_product_dict.items():
randomize_scene()
await rep.orchestrator.step_async()
Preview the scene
await preview_scene(num_previews=1)
Once satisfied with the preview, proceed to create the dataset
with rep.trigger.on_frame(num_frames=100): # Capture 100 frames
randomize_scene()
rep.orchestrator.run()
