LiDAR self-calibration with custom LiDAR: calibration stays at 0% / Not Accepted
DRIVE OS Version: 6.0.10
Issue Description:
Hi everyone,
I’m trying to use the DriveWorks LiDAR self-calibration sample with a Hesai AT128P (custom LiDAR integration), and I’m currently stuck with the calibration status never progressing.
Goal / setup
I want to run the LiDAR self-calibration tool for a Hesai AT128P (custom LiDAR), i.e. use the calibration engine/routine with a LiDAR type that is not natively supported by the calibration module.
For that, I had to adapt the NVIDIA sample code. One adaption is that I had to spoof the LiDAR device string inside the m_lidarPropertiesCalib (dwLidarProperties m_lidarPropertiesCalib{}) (See below for the code).
Also, I use CAN-only egomotion (DW_EGOMOTION_ODOMETRY), no IMU yet.
What already works
Other samples/tools but the calibration sample:
  • Replay / recording (original NVIDIA Driveworks samples) pipeline works
  • Point cloud processing works (I adapted the pointcloudprocessing sample)
Inside this customized calibration sample:
  • Egomotion works (CAN-only, no IMU yet)
    • DW_EGOMOTION_ODOMETRY
    • I feed VehicleIO states from CAN
  • I can compute and use egomotion transforms (not the root issue here)
Observed problem
  • m_updatedLidarToRig remains equal to the nominal transform (m_lidarInfo.nominalSensorToRig)
  • therefore m_correctionR and m_correctionT also remain zero/identity (expected consequence)
  • more importantly: calibration status (dwCalibrationStatus m_status{}) stays at 0.00% / “Not Accepted” the whole time
So I suspect the problem is earlier in the calibration pipeline (initialization / calibration routine setup), not just output interpretation.
Suspected area: calibration routine initialization (dwCalibrationEngine_initializeLidar)
This part succeeds (no error code), but I suspect the routine is internally not configured correctly for my custom LiDAR.
Calibration engine init (no error) (exactly like in the original LiDAR self-calibration sample from DriveWorks!)
CHECK_DW_ERROR_MSG(dwCalibrationEngine_initialize(&m_calibEngine, m_rigConfig, m_context),
                   "Error: Initialize calibration engine failed.");
Calibration routine init (with LiDAR spoofing)
Originally this failed because the calibration module did not support the Hesai LiDAR type.
To work around this, I spoofed the LiDAR device string to a supported Velodyne type:
std::strncpy(reinterpret_cast<char*>(m_lidarPropertiesCalib.deviceString),
             "VELO_HDL64E"
             sizeof(m_lidarPropertiesCalib.deviceString) - 1);
m_lidarPropertiesCalib.deviceString[sizeof(m_lidarPropertiesCalib.deviceString) - 1] = '\0';
dwCalibrationLidarParams lidarCalibrationParams{};
lidarCalibrationParams.lidarProperties = &m_lidarPropertiesCalib;
dwCalibrationEngine_initializeLidar(&m_calibRoutine,
                                    m_lidarInfo.sensorId,
                                    m_canIndex,
                                    &lidarCalibrationParams,
                                    cudaStreamDefault,
                                    m_calibEngine)
I printed the content of dwLidarProperties (the struct passed into dwCalibrationLidarParams::lidarProperties) and noticed clear discrepancies compared to what I expect for my Hesai AT128P recording. That raises the question whether the calibration routine (m_calibRoutine) is initialized successfully but with incorrect LiDAR model assumptions, causing calibration to never converge / never progress.
Observed vs. expected fields of dwLidarPropeties
Field (dwLidarProperties) Observed (logged) Expected (Hesai AT128P, Single Return @10 Hz) Assessment / Comment
deviceString VELO_HDL64E (spoofed!) VELO_HDL64E (spoofed!) Intentionally spoofed
spinFrequency 10 Hz 10 Hz ✅ matches
numberOfRows 128 128 ✅ matches
pointsPerPacket 256 256 ✅ matches (2 blocks × 128 channels)
pointsPerSpin 320000 153600 ❌ much too high (~2.08×)
pointsPerSecond 3200000 1536000 ❌ much too high (~2.08×)
packetsPerSpin 1250 600 ❌ much too high (~2.08×)
packetsPerSecond 12 6000
horizontalFOVStart 0.5 rad convention-dependent
horizontalFOVEnd 2.8 rad convention-dependent
Horizontal FOV Span (End - Start) 2.3 rad ≈ 131.8° about 120° (slightly more in practice)
verticalFOVStart -0.216697 rad (≈ -12.42°) about -12.47° (≈ -0.21764 rad) ✅ very close
verticalFOVEnd 0.224673 rad (≈ +12.87°) about +12.93° (≈ 0.22567 rad) ✅ very close
validAuxInfos 0x0 unknown / mode-dependent ⚠️
lidarSSISizeInBytes 0 unknown / sensor-dependent ⚠️
availableReturns ANY unknown / mode-depent ⚠️
horizontalAngles[] min/max 0 / 0 delta should be around 0,1 °
verticalAngles[] min/max 0 / 0 -12.42°/12.87 ° would normally be expected
Questions
  1. What exactly from the rig is used by dwCalibrationEngine_initialize(&m_calibEngine, m_rigConfig, m_context)
  2. For the LiDAR self-calibration routine:
    • Which fields of dwLidarProperties are actually relevant for calibration?
    • If the fields of the dwLidarProperties are no all correct, can that cause the calibration status to stay at 0% (Not Accepted) without explicit errors?
  3. Can the fields of dwLidarProperties be overridden/set manually and if so, how?
  4. Or is it more likely, that the issue is somewhere elese?
Dear @Jis ,
The dwCalibrationEngine_initialize() only stores the rig; it does not read specific fields at init.
Which fields of dwLidarProperties are actually relevant** for calibration?
It needs deviceString, pointsPerSpin, spinFrequency
Yes.
Let me check if using Velodyne device string is causing this issue and update you
Thank you for that information. Unfortunately I still don’t get how to set them. I rechecked the origional code (from sample_calibration_lidar). This is all I find inside the code about dwLidarProperties:
Relevant Code for dwLidarProperties (from original NVIDIA SDK Calibration Sample)
class LidarSelfCalibrationSample : public DriveWorksSample
    dwLidarProperties m_lidarProperties{};
bool onInitialize() override
        // Initialize lidar accumulator
            dwPointCloudAccumulator_initialize(&m_accumulator, &params, &m_lidarProperties, m_context)
        // Initialize Lidar Self-Calibration
            lidarCalibrationParams.lidarProperties = &m_lidarProperties;
            dwCalibrationEngine_initializeLidar(&m_calibRoutine, m_lidarInfo.sensorId, m_canIndex, &lidarCalibrationParams, cudaStreamDefault, m_calibEngine)
void initializeSensorManager()
        dwSensorManagerParams smParams{};
        m_lidarIndex = getSensorIndex(DW_SENSOR_LIDAR, getArgument("lidar-sensor"));
        smParams.enableSensors[smParams.numEnableSensors++] = m_lidarIndex;
        dwSensorManager_initializeFromRigWithParams(&m_sensorManager, m_rigConfig, &smParams, 1024, m_sal)
        dwSensorManager_getSensorHandle(&lidarSensor, m_lidarIndex, m_sensorManager)
        dwSensorLidar_getProperties(&m_lidarProperties, lidarSensor)
→ So the properties are read out with *_getProperties with help of lidarSensor, which is again set by m_sensorManager. From this I deduce that the information is obtained by the sensorManager, which is set by the rig and m_sal/m_context. So I checked the rigfile of the calibration sample:
And this is the rig-part of the lidar:
Rig (from NVIDIA SDK)
                "correction_rig_T": [
                    0.0,
                    0.0,
                    0.0
                "correction_sensor_R_FLU": {
                    "roll-pitch-yaw": [
                        0.0,
                        0.0,
                        0.0
                "name": "lidar:top:hdl64e",
                "nominalSensor2Rig_FLU": {
                    "roll-pitch-yaw": [
                        2.0,
                        -3.0,
                        -93.0
                    "t": [
                        1.06643998622894,
                        -0.105389997363091,
                        1.94612005233765
                "parameter": "file=lidar_velodyne64.bin",
                "properties": null,
                "protocol": "lidar.virtual"
→ There is no information about the missing fields
Also, here is the lidar-part of my rig:
My Rig
        "name": "lidar:front:center",
        "nominalSensor2Rig": {
          "roll-pitch-yaw": [
            0.0,
            0.0,
            0.0
          "t": [
            3.5775,
            0.0,
            0.5845
        "parameter": "file=.../lidar_front_center.bin,device=CUSTOM_EX, decoder-path=.../libplugin_lidar_hesai_x86_64.so,lidar_type=AT128E2X,correction_file=.../custom_angle_correction_frontcenter201.dat, scan-frequency=10.0",
        "properties": null,
        "protocol": "lidar.virtual",
        "sensor2Rig": {
          "roll-pitch-yaw": [
            0.0,
            0.0,
            0.0
          "t": [
            3.5775,
            0.0,
            0.5845
Following / Still open questions:
In my understanding, this means that the mentioned field pointsPerSpin is read by the sensormanger and not set manually. So how to I override them / set them maually?
Also, exactly those fields are less problematic: deviceString is set (spoofing), spinFrequencyis correct, pointsPerSpin is twice as high but I am guessing this is just used for the capacity, so I think as long as it is not too low it shouldn’t be a problem?
Update 1 : Overwriting m_lidarPropertiesCalib doesn’t solve the issue
I manually overwrote the fields of m_lidarPropertiesCalib (before the initialization), so the following fields are correct (correct means as in the ideal situation) now:
  • Spin Frequency
  • numberofRows
  • packetsPerSecond
  • packetsPerSpin
  • pointsPerSecond
  • PoinsPerSpin
    like this:
m_lidarPropertiesCalib = m_lidarProperties;
// Manually override clearly wrong/inconsistent fields (AT128P, Single Return, 10 Hz)
m_lidarPropertiesCalib.spinFrequency    = 10.0f;
m_lidarPropertiesCalib.numberOfRows     = 128;
m_lidarPropertiesCalib.packetsPerSecond = 6000;
m_lidarPropertiesCalib.packetsPerSpin   = 600;
m_lidarPropertiesCalib.pointsPerSecond  = 1536000;
m_lidarPropertiesCalib.pointsPerSpin    = 153600;
But the calibration still doesn’t work.
Update 2: Timing of LiDAR & CAN is good (just to rule out errors here)
I checked the timestamps of the LiDAR packets, CAN messages and the sweep itself: Within each LiDAR sweep, the egomotion estimates and LiDAR packets arrive in the expected temporal order and are consistently time-aligned. In other words, during the sweep window there is no unexpected timing mismatch between egomotion and LiDAR data.
Update 3: Output if --verbose=1
I don’t see any problems here, but here’s the output of one sweep if --verbose=1:
Adding current ICP pose to calibration engine:
	  1.000000000000	 -0.000174980523	 -0.000114009468	  0.173969864845
	  0.000174967136	  1.000000000000	 -0.000117421761	 -0.003303708509
	  0.000114030016	  0.000117401811	  1.000000000000	  0.007323410828
	  0.000000000000	  0.000000000000	  0.000000000000	  1.000000000000
Adding Ego-Motion pose to calibration engine:
	  1.000000000000	 -0.000007677823	  0.000000000000	  0.174665004015
	  0.000007677823	  1.000000000000	 -0.000000000000	  0.000000670087
	  0.000000000000	  0.000000000000	  1.000000000000	  0.000000000000
Adding 80000 Lidar points to calibration engine.
@SivaRamaKrishnaNV Do you have any update for this topic? Maybe another idea what could cause this or even how to fix it?
Could you please provide any update for this topic?
Duplicate of LiDAR self-calibration stays at 0% / Not Accepted with Hesai AT128P (custom lidar, spoofed as VELO_VLS128)
