Lidar X4 doesn't work
Screenshot from 2022-02-04 08-41-50
  1. I install ydlidar_ros_driver follow this → GitHub - YDLIDAR/ydlidar_ros_driver: ydlidar driver package under ros
  2. When I use roslaunch, lidar stops working after running for a while. (The attached image is the error log for that situation)
  3. When lidar is connected to the USB port and the NANO is turned on, lidar is automatically started. In this case, the keyboard is not connected. If you want to use the keyboard, you need to disconnect and reconnect lidar. However, in this case, lidar does not work as roslaunch and shows the corresponding error log.
  4. If roslaunch fails, the ttyUSB port number jumps from 0 to 1 and again from 1 to 0.
Anyone can help me? When I searched, no one had the same problem as me. That’s why I came here to ask for help because I don’t have any information. please help me.
You can share the dmesg when the error happens so that we can know why the keyboard does not work when lidar is in use.
This is my dmesg
Please always share full log as a text file.
dmesg.txt (56.5 KB)
srr! This is my dmesg log
Is this still a jeston nano devkit?
I see some log that seems should not happen on devkit case.
[ 1.031496] tegra-xusb-padctl 7009f000.xusb_padctl: failed to setup XUSB ports: -517
Yes I use Jetson nano 2GB Devkit and I use 64GB sd card
Hi I’m waiting your awnser and I recognize that I flash Jetson NANO image not Jetson NANO 2GB Image on homepage So I flash 2GB image again and install ydlidar driver. And I get same error again here is my dmesg log Thank you so mach
dmesg2.txt (56.4 KB)
I don’t see any error from your latest dmesg. Are these your usb mouse and keyboard?
[ 2.389936] usb 1-3.2: new low-speed USB device number 5 using tegra-xusb
[ 2.415965] usb 1-3.2: New USB device found, idVendor=1a2c, idProduct=4d7e
[ 2.415971] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.415975] usb 1-3.2: Product: USB Keyboard
[ 2.415978] usb 1-3.2: Manufacturer: SEMICO
[ 2.197950] usb 1-3.1: new low-speed USB device number 4 using tegra-xusb
[ 2.214237] systemd[1]: Detected architecture arm64.
[ 2.222105] usb 1-3.1: New USB device found, idVendor=18f8, idProduct=1286
[ 2.222109] usb 1-3.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.222113] usb 1-3.1: Product: USB GAMING MOUSE
YES It is
Sorry for the late response, is this still an issue to support? Thanks
