/dev/ttyUSB0 no such file or directory when RPLidar A1 is connected to the Jetson Nano 2GB
I have recently bought a Jetson Nano 2GB and an RPLidar A1 (the lidar came in as a new version, with a green board instead of the usual black).
When I plug in the lidar to the jetson and type “ls -l /dev | grep ttyUSB”, nothing shows up; hiwever, the lidar starts spinning. According to the RPLidar A1 instructions, we should be able to see an output “crw-rw---- 1 root dialout 188, 0 Dec 31 20:33 ttyUSB0”
What would be the next steps to make sure the jetson recognizes the lidar? Is the Jetson Nano 2GB compatible with the RPLidar A1?
Thank you very much!
Best regards
please refer to this.
