I am trying to interface the TX2 to a transmitter (not a display) which uses 1LVDS channel (1 pair) and 1 clock channel. I believe that I can modify the DP pins to act as TX2 output. Couple of questions…
Can someone point me a to hardware/cable that connects the display connector on the dev kit to eDP? I can ‘extract’ only the required pins to send data to the transmitter.
Any pointer to any code to send data via the eDP pins?
Thanks in advance.
