I am in the process of configuring a randomized scene utilizing assets provided by NVIDIA. However, I have encountered recurring issues with regards to the textures of said assets. Some textures appear red, while others appear pink, among other discrepancies.
Hello @Sturm_1! I usually see this if you have an incompatible GPU, but you are using a 3060 so the textures should load. Would you be able to attach a copy of your USD file so that I can send it over to the dev team? You can attach it here or email it to me at omniversecommunity@nvidia-omniverse.atlassian.net
Hi @WendyGram ! I start from a blank file and then generate the scene via script. Honestly I never even tried to save it. Now that I try it, Omniverse Code just crashes during the saving process. Here is another log file from when this happens
