we run maya as a “thin client” meaning maya does not get installed on every workstation, just copied over. OV launcher wont detect these types of installs, so the installation of the connector fails. Is there a way to manually download and install the connector?
Currently there is no manual way to install it. But if you want to control it, you can copy the binaries by finding it at C:\Users\user name\AppData\Local\ov\pkg. Then you can manually copy it to other PCs and run MayaSetup.exe in the root folder on the other PCs.
MayaSetup.exe can use argument “/INSTALL” in command line mode. Or “/UNINSTALL” to uninstall.
