Following up from previous posts, we managed to get some live signal reporting during a v4l2 stream.
Our HW design follows the one for ov5693, such that physical connectivity is through CSI2 port.
The original dtsi file stated:
tegra_sinterface = "serial_c";
Can changing the definition to serial_a cause any trouble? (So that the serial interface is directly connected to the physical port)
Or the only relevant configuration between the dtsi and the physical port resides under vi {ports {port}} and nvcsi { channel {ports {port}}} subsections?
Currently, the response always returns the familiar (no other status code is present):
rtcpu_nvcsi_intr: .... class:CORRECTABLE_ERR type:PHY_INTR phy:1 cil:0 st:0 vc:0 status: 0x00000040
rtcpu_nvcsi_intr: .... class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status: 0x00000040
According to the TRM this means the bit intr_cil_data_lane_sot_mb_err1_a is on, but not for err0.
What can be the cause for this? (not both being set for example).
If that’s a hint to search for improper signal form.
Thanks,
Moti.
