my custom board replace sensor with 2 4-lane sensor(csi2/3 and csi4). how should i edit the dts files?
i use tegra210-p3448-0000-p3449-0000-b00.dts.
the port-index shouild be 2 and 4? and bus-width should be 4?
and the i2c i use cam_i2c and i2c2, how can i adapt it? my custom board remove the cam_mux_sel
Have check this doc.
what aboat the i2c port?
Have a reference to the reference sensor board like below define the sensor below the i2c@546c0000
host1x {
27 i2c@546c0000 {
28 ov5693_c@36 {
29 /* Define any required hw resources needed by driver */
30 /* ie. clocks, io pins, power sources */
31 /* mclk-index indicates the index of the */
32 /* mclk-name with in the clock-names array */
33
34 clocks = <&tegra_car TEGRA210_CLK_CLK_OUT_3>;
35 clock-names = "clk_out_3";
Hi, ShaneCCC
my mclk have no signal,how can i fix it?
Add some message to below file to check if it set properly.
./camera/camera_common.c: err = of_property_read_string(np, “mclk”, &pdata->mclk_name);
Because of the imx219’s dts-file have not label mclk.
so should i insert the label to there? and what’s the value should be?
host1x {
i2c@546c0000 {
rbpcv2_imx219_a@36 {
status = “disabled”;
clock-names = “clk_out_3”;
clock-frequency = <24000000>;
mclk = “clk_out_3”;
reset-gpios = <&gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
i2c@7000c500 {
rbpcv2_imx219_e@36 {
status = "disabled";
mclk = "clk_out_3";
reset-gpios = <&gpio CAM2_PWDN GPIO_ACTIVE_HIGH>;
i add label mclk clocks and so on. and mclk has signal. but mipi no data. how can i get the log of mipi,that i can confirm the sensor is init ok (i can get/set sensor register).
the b01 camera0/camera1 use csi0/2, but the label port-index of dts-file is 0/4. so if camera0/camera1 use csi2/4, the label port-index of dts-file will be 4/8?
The port-index is the same with csi number, csi0 then port-index=0
hi ShaneCCC, how can i get the log of mipi data?
You can enable the dev_dbg() in csi2_fops.c to print the status for checked.
[ 4899.146317] video4linux video1: frame start syncpt timeout!0
[ 4899.152509] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4899.152526] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4899.152542] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4899.152663] vi 54080000.vi: cil_settingtime was autocalculated
[ 4899.152682] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4899.354060] video4linux video1: frame start syncpt timeout!0
[ 4899.360308] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4899.360326] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4899.360342] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4899.360432] vi 54080000.vi: cil_settingtime was autocalculated
[ 4899.360450] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4899.562367] video4linux video1: frame start syncpt timeout!0
[ 4899.568723] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4899.568740] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4899.568755] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4899.568846] vi 54080000.vi: cil_settingtime was autocalculated
[ 4899.568864] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4899.770343] video4linux video1: frame start syncpt timeout!0
[ 4899.776617] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4899.776634] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4899.776649] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4899.776770] vi 54080000.vi: cil_settingtime was autocalculated
[ 4899.776788] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4899.978184] video4linux video1: frame start syncpt timeout!0
[ 4899.984503] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4899.984521] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4899.984536] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4899.984674] vi 54080000.vi: cil_settingtime was autocalculated
[ 4899.984694] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4900.186298] video4linux video1: frame start syncpt timeout!0
[ 4900.192553] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4900.192570] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4900.192586] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4900.192713] vi 54080000.vi: cil_settingtime was autocalculated
[ 4900.192732] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4900.394308] video4linux video1: frame start syncpt timeout!0
[ 4900.400594] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4900.400611] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4900.400627] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4900.400756] vi 54080000.vi: cil_settingtime was autocalculated
[ 4900.400774] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4900.602020] video4linux video1: frame start syncpt timeout!0
[ 4900.609185] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4900.609204] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4900.609221] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4900.609355] vi 54080000.vi: cil_settingtime was autocalculated
[ 4900.609373] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4900.810296] video4linux video1: frame start syncpt timeout!0
[ 4900.816486] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4900.816504] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4900.816520] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4900.816645] vi 54080000.vi: cil_settingtime was autocalculated
[ 4900.816664] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4901.018145] video4linux video1: frame start syncpt timeout!0
[ 4901.024232] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4901.024243] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4901.024254] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4901.024330] vi 54080000.vi: cil_settingtime was autocalculated
[ 4901.024343] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4901.226073] video4linux video1: frame start syncpt timeout!0
[ 4901.232020] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4901.232032] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4901.232044] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4901.232128] vi 54080000.vi: cil_settingtime was autocalculated
[ 4901.232140] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4901.434332] video4linux video1: frame start syncpt timeout!0
[ 4901.440474] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4901.440528] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4901.440578] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4901.440794] vi 54080000.vi: cil_settingtime was autocalculated
[ 4901.440815] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4901.642269] video4linux video1: frame start syncpt timeout!0
[ 4901.648376] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4901.648397] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4901.648415] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4901.648504] vi 54080000.vi: cil_settingtime was autocalculated
[ 4901.648523] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
[ 4901.850133] video4linux video1: frame start syncpt timeout!0
[ 4901.856032] vi 54080000.vi: TEGRA_CSI_PIXEL_PARSER_STATUS 0x00000000
[ 4901.856042] vi 54080000.vi: TEGRA_CSI_CIL_STATUS 0x00000010
[ 4901.856050] vi 54080000.vi: TEGRA_CSI_CILX_STATUS 0x00040041
[ 4901.856106] vi 54080000.vi: cil_settingtime was autocalculated
[ 4901.856114] vi 54080000.vi: csi clock settle time: 13, cil settle time: 10
i use v4l2-demo and the log.
the demo stuck in VIDIOC_DQBUF.
Below error tell the clock/data lane control error have a check the REG CSI_CSI_CILA_STATUS_0 and CSI_CSI_CIL_A_STATUS_0 from the TRM.
It could be the sensor with continous clock mode and enable sensor streaming before enable NVCSI.
hi shane, so is it REG issue?
hi shane, where can i get the doc of REG?
hi shane,
what’s the diffrent of csi4_fops.c and csi2_xxxx.c?
