New Jetson AGX Orin developers kit fails 6.1 update
Hi. First post. The ORIN was fine out of the box booting up Ubuntu. Waited to not do much before 6.1 update ordered my new Ubuntu host Ubuntu 22.04.5 LTS. Got it installed the sdkmanager all ran fine it seemed success but the restart on the kit failed to display anything. I did realize I was not holding the button long enough to go into recovery mode but that seemed to not really change any results. I get a reset screen and all passes by on that same hdmi I have been using. Have tried a number of things like flashing to the added ssd card but all ends up with no display. One attempt I did not select oem and did get the config screen for Ubuntu welcome but end the end it just sent blank. Maybe a bad oem-config. Next I was going to try an older release like 5.1 to see if the display comes up. BTW it seems sdkmanager thinks all is ok even in the repair/remove screen. I was able to remove previous installs and reinstall with same results. Any advise would be welcome. Thank you.
SDKM_logs_JetPack_6.1_(rev._1)Linux_for_Jetson_AGX_Orin[64GB_developer_kit_version]_2024-12-18_01-21-39.zip|attachment (479.0 KB)
Sorry for the late response. not sure if this is still an issue, if still needs support, please open your issue at AGX Orin forum: Latest Jetson & Embedded Systems/Jetson AGX Orin topics - NVIDIA Developer Forums
