Hi, I tried to reflash the Orin by sdkmanager1.8.2 on a Ubuntu 20.04 host PC(not VM), and the Orin was connected to the PC through the USB-C port next to the 40-pin connector, but the Orin can not be detected. I need some help.
And I have created a similar topic before. But at that time, I was using 20.04 VM.
And even if I follow the command in the prompt(1. sudo apt-get update && sudo apt-get check; 2. sudo dpkg --audit), the prompt will reappear.
Do you know why?
The error has no standard answer. This is related to your host apt problem and it would be case by case.
A solution may be working on one user’s host but may fail on another user’s host.
Just need to make sure your apt-get update gives no error.
Thanks for your reply.
I do need support, but not this issue.
It’s described in another topic that I created.
It’s about ‘automatically power off’.
Thanks for your support if you have time to check it out.
