I know it’s very similar to: topic|help/247392, but the difference is the last line:
EFI stub: Exiting boot services and installing virtual address map…
Anyway I tried solution from linked topic (press recovery button and unplug power), but it didn’t worked. Should I leave it over night to complete this “virtual mapping”?
And second question,
if it won’t boot, how can I write fresh system? Thanks.
Hi, I was following this guide, maybe I misspelled the version…? I had jetpack 5.0.1 and installed 5.1.2, I had some errors during the upgrade, but when I checked jetpack version it showed 5.1.2, but after ‘sudo reboot’ boot problem appeared.
I downloaded sdkmanager on my personal amd linux machine, but the process freezes on 31.25%
I probably can’t put the board into recovery mode.
I tried advice from this topic , but when I’m clicking the buttons, even LED is not flashing.
I have connected only USB-c cable to port next to 40pins. Should I connect power supply to the second USB-c?
It’s a known issue that has been around for a while…
We are still debugging it.
Currently what we can suggest is that avoid virtual machines, use Ubuntu 18.04 instead of 20.04, try with a different USB cable/port, or the following command:
Command didn’t help, different cable didn’t help. Finally I downgrade my ubuntu to 18.04 and it worked! I recovered the system installed the new Jetpack. I can connect with it via cabel
(ssh XYZ@192.168.55.1), but how to connect with the board via wireless ssh? I tried find address with ip a but it seems that ssh is turned off?
I mixed up the concepts… I just want to connect Jetson to wifi, but wlan0 seems to be turned off and I have problems to configure it via terminal. Do you know if system from sdkmanager is headless or it is desktop version?
