I can’t boot the Jetson to desktop after trying to rebuild the kernel after not being able to connect an xbox controller via Bluetooth. I need to reset this Jetson and upgrade it to Jetpack 6.0. I can’t force it into recovery mode with the side buttons and I tried to see if there’s a way to do it via the terminal but can’t get a terminal as it won’t complete booting up to desktop.
Is there a way to reset the Jetson via sdkmanager, USB, or SSD? I have been trying for the past few days and can’t find a way yet.
14:27:53.108 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS: Waiting for target to boot-up...
14:27:53.109 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS:
14:27:54.111 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS: Timeout
14:27:54.111 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS: Device failed to boot to the initrd flash kernel. Please retrive the serial log during flashing to debug further.
14:27:54.112 - info: NV_L4T_FLASH_JETSON_LINUX_COMP@JETSON_AGX_ORIN_TARGETS: Cleaning up...
From the log you shared, it seems you failed at Step 3 to wait the board boot up.
It may be caused from your board boot failed.
Please share the full serial console log from the devkit for further check.
I changed the PSU to the USB-C power adapter included with the kit and that got past that error but them more errors appeared so will try again and update when I collect more info
