No boot menu showing up After JetPack 6.0 DP successfully installed
After installing JetPack 6.0 DP for my new Orin Nx 16gb using sdkmanager, the boot menu didn’t show up. It was basically black screen. I was using Nvidia official Jetson orin nano development Board for the installation. I tried multiple times, every time it shows the installation was successful but there is no boot menu. Then after that I successfully installed Jetpack 5.1.3 in my orin nx which is now running without any issue. Is there any fix to that problem? Here I am attaching the log file.
flash_3-1_0_20240222-231904.log (51.7 KB)
Dump the log, please:
Also, please make sure the display cable is already plugged-in during flashing, or there’s currently a bug that boot menu will never show up no matter how many times you reboot the device.
Thank you for your response, I will upload debug console log.
During the installation time, the HDMI cable was already connected. The Nvidia boot screen just once showed up in the middle of flushing but then it was black always and didn’t show any boot screen or login screen or anything else even after flushing is successful.
I tried again to install jeckpack 6.0 DP on my orin nx, now I was successfully able to boot in to the system. Thanks :D.
