I need your help.
My jetson xavier NX was working fine after installing Jetpack 4.6 (JetPack SDK 4.6.1 | NVIDIA Developer) using micro sd card.
However, I required to install latest Jetpack 5.0. So, I “Downloaded SD Card Image for JetPack 5.0 DP” from JetPack SDK | NVIDIA Developer by following the SD Card Image method and wrote the image to the microSD Card (Getting Started With Jetson Xavier NX Developer Kit | NVIDIA Developer).
Jetpack 5.0. DP" was successfully uploaded but after an update it failed to display anything on the screen.
I spent 4 days to fix this problem but the problem of Jetpack 5.0 was still there. it does not boot and does not show anything on the screen.
I have also tried to use SDK manager method but it was not detecting the board.
Both SDK Manager and MicroSD Card method did not worked for to use Jetpack 5.0.
Therefore, instead of spending more time on it, I thought to use the Jetpak 4.6 that I was already using before installing the Jetpack 5.0. Because Jetpack 4.6 did not such issue and it was working fine.
So, I downloaded Jetpack 4.6 again using MicroSD Card method.
I have always used MicroSD card method for installation of different Jetpack 4 version and it always worked for me.
However, this time, jetson xavier does not show anything on the screen when I install Jetpack 4.6.
I have faced this problem after Jetpack 5.0 update.
Since the Jetpack 5.0 updates, my xavier NX has stopped displaying anything on the screen.
And now, when I am trying to install Jetpack 4.6 instead of Jetpack 5.0,
It is still not displaying anything on the screen to boot.
I need to install Jetpack 4.6 now. So, in this situation, how can I do it?
Thank You
