I set up the Jetson Nano according to the setup guide by flashing a micro SD card. I then plugged in HDMI, USB keyboard and mouse, and powered it through the USB port. The module powered up and let me do the initial setup for username and passwords and then I plugged in the ethernet cable. It then proceeded to install a few packages and then shut down and never powered back up again. The green LED near the micro USB is on when I power it with either the micro USB or barrel jack (5V 4A) but there is no feedback from the monitor, not even the splash screen.
I then tried booting in recovery and tried flashing jetpack with sdkmanager. It flashes the image (installation goes till 50%) and then doesn’t proceed further. Any advice on what might be going wrong?
I am having a very similar issue. I setup my Nano without any issues, but after powering it off, I have been having some issues.
Specifically, I see that the green LED is on, indicating that the device is powered, but nothing is shown on my display and the Nano is not able to power any peripheral devices. nredla, which “different cables” did you try to fix the issue?
Just receive Nano one hour ago. Setup done and now green led after booting is ON and then OFF after a minute.
Power supply is 2A. I try to remove all cable, HDMI, USB and only keep power supply thru miniUSB.
Unfortunately, got same issue, LED turn off after few second.
As our suggestions, you’ll need to power the developer kit with a good quality power supply that can deliver 5V⎓2A at the developer kit’s Micro-USB port. Not every power supply rated at “5V⎓2A” will actually do this.
Please try with another power source to see if can work well.
