Getting an “abort” error found below. I’ve installed the NVIDIA 6.5 toolkit cleanly and successfully and I’m not aware of any issues with my OS. Applied to the NVIDIA dev program so I can report the error - I really need Nsight to launch. Thanks in advance for any help in getting the tool to actually run
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x00007fff8678ad10, pid=63960, tid=1287
JRE version: Java™ SE Runtime Environment (7.0_60-b19) (build 1.7.0_60-b19)
Java VM: Java HotSpot™ 64-Bit Server VM (24.60-b09 mixed mode bsd-amd64 compressed oops)
Problematic frame:
C [libobjc.A.dylib+0x1cd10] -[NSObject superclass]+0x11
Failed to write core dump. Core dumps have been disabled. To enable core dumping, try “ulimit -c unlimited” before starting Java again
An error report file with more information is saved as:
/Developer/NVIDIA/CUDA-6.5/libnsight/nsight.app/Contents/MacOS/hs_err_pid63960.log ( uploaded here: http://pastebin.com/MsxqS5tf )
/Developer/NVIDIA/CUDA-6.5/bin/nsight: line 3: 63960 Abort trap: 6 PATH=$PATH:$CUDA_BIN DYLD_LIBRARY_PATH=$DYLD_LIBRARY_PATH:$CUDA_BIN/…/lib $CUDA_BIN/…/libnsight/nsight.app/Contents/MacOS/nsight $@
