In Omniverse Nucleus, when I invite other members and they click on the invitation link and enter the password, the prompt “The link has expired.” appears. How can this problem be solved?
Thanks a lot
This is because you’re sharing the user link from your localhost server (which won’t work on their machines). If you are sharing Nucleus workstation, you must first add the server to your own list, with the IP those users would access with, and share that link out.
Thank you for your response. I’m sure me and my workmates are in one same local net. So, do you mean that I need to first use someone else’s IP to search their local services and then add that user to the users list?
Yes, since you’re talking about sharing this with other users, I’m assuming they are not using the same machine Nucleus is running on.
Please follow the instructions in our documentation
Using Nucleus Workstation — Omniverse Nucleus latest documentation (nvidia.com)
ok, let me try again. Thank you!
