Operating System:
Linux
Kit Version:
107 (Kit App Template)
Kit Template:
USD Composer
GPU Hardware:
50 series - 5070Ti
GPU Driver:
Latest
I am attempting to run the Neural Reconstruction (Stereo Camera Flow) pipeline by strictly following the official documentation: https://docs.nvidia.com/nurec/robotics/neural_reconstruction_stereo.html
I am using the official sample dataset (r2b_galileo) provided by NVIDIA, not custom data. However, I am encountering significant issues with reconstruction quality and coordinate alignment in Isaac Sim.
My Environment:
Dataset: Official NVIDIA
r2b_galileo -
ISAAC ROS Version: 3.1.0 (Jazzy)
Pipeline: CuSFM → FoundationStereo → Nvblox & Gaussian Splatting
Issue 1: Severe Spikes and Noise (Despite Parameter Tuning) Even though I followed the provided flow exactly using the sample dataset, the resulting Mesh and Gaussian Splatting outputs are filled with severe “spikes” (Gaussian artifacts) and noise.
I have already tried the following to resolve this, but the issue persists:
Strict Adherence to Flow: Followed the documentation step-by-step.
Distance/Depth Parameter Tuning: I adjusted parameters related to distance filtering (e.g.,
projective_integrator_max_integration_distance_m, and depth estimation ranges) to cut off outliers, but it did not help.
Issue 2: Coordinate System Mismatch in Isaac Sim When I import the resulting Mesh (.ply from nvblox) and the Gaussian Splatting output (.ply) into Isaac Sim, they do not align with each other.
The Mesh and the Gaussian model seem to have different origins or orientations.
I suspect this is related to the
fit_to_z0option or world frame settings, but I need them to overlap perfectly.
Questions:
Why does the official
r2b_galileodataset produce such noisy results with the default configuration? Is there a specific config file for this dataset? -
How can I enforce the exact same coordinate system for both Nvblox and Gaussian Splatting so they align perfectly in Isaac Sim?
Any guidance would be appreciated.
