(NVIDIA Jetson TX2 ) SDK Manager can't detect Target Hardware "no board connected"
I’m using virtualbox of ubuntu 18.04 flashing Jetson TX2 by SDK Manager
problem: my virtualbox of ubuntu 18.04 can’t detact target Hardware Jetson TX2, but local pc with Ubuntu 20.04 could, I want virtualbox ubuntu 18.04 detact too
virtualbox of ubuntu 18.04: cannot sense the target Hardware Jetson TX2
local pc with Ubuntu 20.04: can sense the target Hardware Jetson TX2
The VM is not supported by SDK manager.
cause my original system is using ubuntu 20.04 instaed of downgrade my whole pc to ubuntu 18.04 I think VM was the good solution
I see some of the demo is using vm ubuntu 18.04 too, so that I think from here might get some way to solve it??
by the way, I also see the ubuntu 18.04 is support until 2023
get any idea for virtualbox of ubuntu 18.04 can’t detact target Hardware Jetson TX2 ?
before I really have to downgrade whole system…
I can’t answer this due to officially flashing Jetson devices from VM is not supported, but you may refer to below topic to see if can help:
thanks
I found the way that used the USB passthrough feature can solve it
the result pic: by adding/connecting usb port to the virtualbox system, now SDK manager can detect Target hardware Tx2 in vm
pic support
I follow this video:(for linux) Enable USB support on VirtualBox - YouTube
