Hello. I am trying to setup Nvidia Jetson Xavier AGX. However, while setup process we are facing with an issue that ‘Warning:Test Key is used’. We couldn’t find any solution for this problem. I hope you can help us.
Did you ever reflash the board or it is just a out-of-box fresh devcie?
Yes, we did reflash.
Please follow this page to dump serial console log and share it here.
Please always share text log instead of screenshot…
error.txt (122.0 KB)
Each line of your log is being truncated… please dump it again.
Compare the txt file with your screenshot and you will understand what I mean.
BTW, is this a custom board but not nv devkit, right?
We tried to dump it again and here is the log file. Also yes this is not nv devkit. The log file is exactly the same with what we see on terminal.
error.txt (54.2 KB)
Each of line is still truncated… do you really understand what issue I am talking about…?
Have you ever read your own log ?? Didn’t you notice each line just get cut in the same location?
error.txt (67.8 KB)
Can you check it again pls.
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
This log is already booting into recovery image. Which is pointless to check… please reflash your board again and dump the log again…
