Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I have downloaded latest DriveOs 6.0.6 for Orin. I wanted to try the sample nvsipl examples as the camera vendor uses the same example for capturing frames. I tried building using the make command. When i try run the executable or at least to see the help of the executable i get an error. Below is the error.
/lib/ld-linux-aarch64.so.1: No such file or directory
Am i doing something wrong in running make? Is there any good reference documentation with proper steps?
Actually all applications under drive-linux/samples fails.
My aim was to try build sample application of nvsipl and then build on top of it while i receive the actual hw which is in shipment. Is there a dependency that since there are no crosscompiled libraries for these nvmedia low level libraries (read from older posts), I may not be able to build on docker in host machines?
Thanks!!
Dear @jishnuw ,
I don’t see any build issues on 6.0.6 docker. It does cross compilation for target. Please check running the sample on target.
root@6.0.6.0-0004-build-linux-sdk:/drive/drive-linux/samples/nvmedia# make clean
test ! -r nvsipl/Makefile || make -C nvsipl clean
make[1]: Entering directory '/drive/drive-linux/samples/nvmedia/nvsipl'
test ! -r query/Makefile || make -C query clean
make[2]: Entering directory '/drive/drive-linux/samples/nvmedia/nvsipl/query'
../../../../make/nvdefs.mk:166: Defaulting NV_WINSYS to x11; legal values are: egldevice wayland x11 direct-to-display
find . -name '*.so' -exec echo rm {} + -exec rm {} +
find . -name '*.o' -exec echo rm {} + -exec rm {} +
find . -name 'json_data.cpp' -exec echo rm {} + -exec rm {} +
make[2]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl/query'
test ! -r devblk/Makefile || make -C devblk clean
make[2]: Entering directory '/drive/drive-linux/samples/nvmedia/nvsipl/devblk'
make[2]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl/devblk'
test ! -r test/camera/Makefile || make -C test/camera clean
make[2]: Entering directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/camera'
../../../../../make/nvdefs.mk:166: Defaulting NV_WINSYS to x11; legal values are: egldevice wayland x11 direct-to-display
rm -rf CUtils.o main.o CComposite.o CCompositeNvSci.o CNvWfd.o nvsipl_camera
make[2]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/camera'
test ! -r test/sample/Makefile || make -C test/sample clean
make[2]: Entering directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/sample'
rm -rf CImageManager.o CUtils.o main.o nvsipl_sample
make[2]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/sample'
test ! -r test/plugin/Makefile || make -C test/plugin clean
make[2]: Entering directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/plugin'
rm -rf CSamplePlugin.o libnvsipl_sampleplugin.so
make[2]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/plugin'
make[1]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl'
python database/gen_json_header.py -inputFiles database/ds90ub971tpg/ds90ub971_tpg_sensor.json database/ds90ub971tpg/ds90ub971_tpg_platform.json database/ds90ub971tpg/ds90ub971_tpg.json -outputFile database/ds90ub971tpg/json_data.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I./include -I../include -I./src -I./database -std=c++14 -fexceptions -frtti -fPIC -c -o database/ds90ub971tpg/json_data.o database/ds90ub971tpg/json_data.cpp
echo "OBJECTS: database/ds90ub971tpg/json_data.o"
echo "JSON: database/ds90ub971tpg/ds90ub971_tpg_sensor.json database/ds90ub971tpg/ds90ub971_tpg_platform.json database/ds90ub971tpg/ds90ub971_tpg.json"
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -shared -L/drive/drive-linux/lib-target -Wl,--no-undefined -o database/ds90ub971tpg/libnvsipl_qry_ds90ub971tpg.so database/ds90ub971tpg/json_data.o -ljsoncpp -lstdc++ -ldl -L/drive/drive-linux/lib-target -Wl,--no-undefined
python database/gen_json_header.py -inputFiles database/max96712tpg/max96712_tpg_sensor.json database/max96712tpg/max96712_tpg_platform.json database/max96712tpg/max96712_tpg.json database/max96712tpg/max96712_tpg_yuv_sensor.json database/max96712tpg/max96712_tpg_yuv_platform.json database/max96712tpg/max96712_tpg_yuv.json database/max96712tpg/max96712_tpg_usecase_platform.json database/max96712tpg/max96712_tpg_2880x1860_yuv_platform.json database/max96712tpg/max96712_tpg_serializer.json -outputFile database/max96712tpg/json_data.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I./include -I../include -I./src -I./database -std=c++14 -fexceptions -frtti -fPIC -c -o database/max96712tpg/json_data.o database/max96712tpg/json_data.cpp
echo "OBJECTS: database/max96712tpg/json_data.o"
echo "JSON: database/max96712tpg/max96712_tpg_sensor.json database/max96712tpg/max96712_tpg_platform.json database/max96712tpg/max96712_tpg.json database/max96712tpg/max96712_tpg_yuv_sensor.json database/max96712tpg/max96712_tpg_yuv_platform.json database/max96712tpg/max96712_tpg_yuv.json database/max96712tpg/max96712_tpg_usecase_platform.json database/max96712tpg/max96712_tpg_2880x1860_yuv_platform.json database/max96712tpg/max96712_tpg_serializer.json"
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -shared -L/drive/drive-linux/lib-target -Wl,--no-undefined -o database/max96712tpg/libnvsipl_qry_max96712tpg.so database/max96712tpg/json_data.o -ljsoncpp -lstdc++ -ldl -L/drive/drive-linux/lib-target -Wl,--no-undefined
python database/gen_json_header.py -inputFiles database/ov2311/ov2311p_platform.json database/ov2311/ov2311p.json database/ov2311/ov2311pl.json database/ov2311/ov2311.json -outputFile database/ov2311/json_data.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I./include -I../include -I./src -I./database -std=c++14 -fexceptions -frtti -fPIC -c -o database/ov2311/json_data.o database/ov2311/json_data.cpp
echo "OBJECTS: database/ov2311/json_data.o"
echo "JSON: database/ov2311/ov2311p_platform.json database/ov2311/ov2311p.json database/ov2311/ov2311pl.json database/ov2311/ov2311.json"
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -shared -L/drive/drive-linux/lib-target -Wl,--no-undefined -o database/ov2311/libnvsipl_qry_ov2311.so database/ov2311/json_data.o -ljsoncpp -lstdc++ -ldl -L/drive/drive-linux/lib-target -Wl,--no-undefined
python database/gen_json_header.py -inputFiles database/serdes/ds90ub9724.json database/serdes/ds90ub971.json database/serdes/cnvm_tpg_deserializer.json database/serdes/max96717.json database/serdes/max96759.json database/serdes/max9295.json database/serdes/max96712_fusa.json database/serdes/max96705.json database/serdes/max96712.json database/serdes/max96717f.json -outputFile database/serdes/json_data.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I./include -I../include -I./src -I./database -std=c++14 -fexceptions -frtti -fPIC -c -o database/serdes/json_data.o database/serdes/json_data.cpp
echo "OBJECTS: database/serdes/json_data.o"
echo "JSON: database/serdes/ds90ub9724.json database/serdes/ds90ub971.json database/serdes/cnvm_tpg_deserializer.json database/serdes/max96717.json database/serdes/max96759.json database/serdes/max9295.json database/serdes/max96712_fusa.json database/serdes/max96705.json database/serdes/max96712.json database/serdes/max96717f.json"
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -shared -L/drive/drive-linux/lib-target -Wl,--no-undefined -o database/serdes/libnvsipl_qry_serdes.so database/serdes/json_data.o -ljsoncpp -lstdc++ -ldl -L/drive/drive-linux/lib-target -Wl,--no-undefined
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/max96712tpg/CNvMMAX96712TPG.o cameramodule/MAX96712cameramodule/max96712tpg/CNvMMAX96712TPG.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMMAX96712_9295CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_9295CameraModule.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMMAX96712_TPGSerializerCameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_TPGSerializerCameraModule.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMMAX96712_96705CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96705CameraModule.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMMAX96712_96717FCameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96717FCameraModule.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96705.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96705.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMMAX96712CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712CameraModule.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMMAX96712_96759CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96759CameraModule.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMMAX96712_96717CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96717CameraModule.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96717.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96717.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96759.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96759.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_TPGSerializer.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_TPGSerializer.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_9295.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_9295.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/common/TransportLinkIF/CNvMTransportLink.o cameramodule/common/TransportLinkIF/CNvMTransportLink.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/common/EEPROMIF/CNvMEEPROM.o cameramodule/common/EEPROMIF/CNvMEEPROM.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/common/SerializerIF/CNvMSerializer.o cameramodule/common/SerializerIF/CNvMSerializer.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/common/SensorIF/CNvMSensor.o cameramodule/common/SensorIF/CNvMSensor.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/common/PMICIF/CNvMPMIC.o cameramodule/common/PMICIF/CNvMPMIC.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/MAX9295ASerializerDriver/CNvMMax9295.o devices/MAX9295ASerializerDriver/CNvMMax9295.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/MAX9295ASerializerDriver/cdi_max9295.o devices/MAX9295ASerializerDriver/cdi_max9295.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/MAX96705SerializerDriver/CNvMMax96705.o devices/MAX96705SerializerDriver/CNvMMax96705.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/MAX96705SerializerDriver/cdi_max96705.o devices/MAX96705SerializerDriver/cdi_max96705.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/MAX96712DeserializerDriver/CNvMMax96712.o devices/MAX96712DeserializerDriver/CNvMMax96712.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/MAX96712DeserializerDriver/cdi_max96712.o devices/MAX96712DeserializerDriver/cdi_max96712.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/MAX96717FSerializerDriver/CNvMMax96717F.o devices/MAX96717FSerializerDriver/CNvMMax96717F.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/MAX96717FSerializerDriver/cdi_max96717f.o devices/MAX96717FSerializerDriver/cdi_max96717f.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/MAX96759SerializerDriver/CNvMMax96759.o devices/MAX96759SerializerDriver/CNvMMax96759.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/MAX96759SerializerDriver/cdi_max96759.o devices/MAX96759SerializerDriver/cdi_max96759.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/N24C64EEPROMDriver/cdi_n24c64.o devices/N24C64EEPROMDriver/cdi_n24c64.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/TPGSerializerDriver/CNvMTPGSerializer.o devices/TPGSerializerDriver/CNvMTPGSerializer.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/TPGSerializerDriver/cdi_tpgserializer.o devices/TPGSerializerDriver/cdi_tpgserializer.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/TPGSerializerDriver/TPGSensorSerializerUtility.o devices/TPGSerializerDriver/TPGSensorSerializerUtility.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o ../../utils/log_utils.o ../../utils/log_utils.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o ../../utils/thread_utils.o ../../utils/thread_utils.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/common/utils/pwr_utils_stub.o cameramodule/common/utils/pwr_utils_stub.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/MAX20087Driver/CNvMMax20087.o devices/MAX20087Driver/CNvMMax20087.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/MAX20087Driver/CNvMMax20087SyncAdapter.o devices/MAX20087Driver/CNvMMax20087SyncAdapter.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/MAX20087Driver/CNvMMax20087Factory.o devices/MAX20087Driver/CNvMMax20087Factory.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/MAX20087Driver/cdi_max20087.o devices/MAX20087Driver/cdi_max20087.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/common/CampwrIF/CNvMCampwr.o cameramodule/common/CampwrIF/CNvMCampwr.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -shared -L/drive/drive-linux/lib-target -Wl,--no-undefined -o devices/MAX20087Driver/libnvsipl_devblk_campwr_max20087.so devices/MAX20087Driver/CNvMMax20087.o devices/MAX20087Driver/CNvMMax20087SyncAdapter.o devices/MAX20087Driver/CNvMMax20087Factory.o devices/MAX20087Driver/cdi_max20087.o cameramodule/common/CampwrIF/CNvMCampwr.o -lnvos -lnvsipl_devblk_cdi -lnvsipl_devblk_ddi -lnvsipl_devblk_crypto -lstdc++ -ldl -lpthread -L/drive/drive-linux/lib-target -Wl,--no-undefined
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -shared -L/drive/drive-linux/lib-target -Wl,--no-undefined -o cameramodule/MAX96712cameramodule/max96712tpg/libnvsipl_devblk_drv_max96712tpg.so cameramodule/MAX96712cameramodule/max96712tpg/CNvMMAX96712TPG.o cameramodule/MAX96712cameramodule/CNvMMAX96712_9295CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_TPGSerializerCameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96705CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96717FCameraModule.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96705.o cameramodule/MAX96712cameramodule/CNvMMAX96712CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96759CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96717CameraModule.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96717.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96759.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_TPGSerializer.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_9295.o cameramodule/common/TransportLinkIF/CNvMTransportLink.o cameramodule/common/EEPROMIF/CNvMEEPROM.o cameramodule/common/SerializerIF/CNvMSerializer.o cameramodule/common/SensorIF/CNvMSensor.o cameramodule/common/PMICIF/CNvMPMIC.o devices/MAX9295ASerializerDriver/CNvMMax9295.o devices/MAX9295ASerializerDriver/cdi_max9295.o devices/MAX96705SerializerDriver/CNvMMax96705.o devices/MAX96705SerializerDriver/cdi_max96705.o devices/MAX96712DeserializerDriver/CNvMMax96712.o devices/MAX96712DeserializerDriver/cdi_max96712.o devices/MAX96717FSerializerDriver/CNvMMax96717F.o devices/MAX96717FSerializerDriver/cdi_max96717f.o devices/MAX96759SerializerDriver/CNvMMax96759.o devices/MAX96759SerializerDriver/cdi_max96759.o devices/N24C64EEPROMDriver/cdi_n24c64.o devices/TPGSerializerDriver/CNvMTPGSerializer.o devices/TPGSerializerDriver/cdi_tpgserializer.o devices/TPGSerializerDriver/TPGSensorSerializerUtility.o ../../utils/log_utils.o ../../utils/thread_utils.o cameramodule/common/utils/pwr_utils_stub.o -lnvos -lnvsipl_devblk_cdi -lnvsipl_devblk_ddi -lnvsipl_devblk_crypto -lstdc++ -ldl -lpthread -L/drive/drive-linux/lib-target -Wl,--no-undefined -Ldevices/MAX20087Driver -lnvsipl_devblk_campwr_max20087
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/MAX96712cameramodule/ov2311/CNvMMAX96712_9295_OV2311.o cameramodule/MAX96712cameramodule/ov2311/CNvMMAX96712_9295_OV2311.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o cameramodule/MAX96712cameramodule/ov2311/cdi_ov2311.o cameramodule/MAX96712cameramodule/ov2311/cdi_ov2311.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -shared -L/drive/drive-linux/lib-target -Wl,--no-undefined -o cameramodule/MAX96712cameramodule/ov2311/libnvsipl_devblk_drv_ov2311.so cameramodule/MAX96712cameramodule/ov2311/CNvMMAX96712_9295_OV2311.o cameramodule/MAX96712cameramodule/ov2311/cdi_ov2311.o cameramodule/MAX96712cameramodule/CNvMMAX96712_9295CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_TPGSerializerCameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96705CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96717FCameraModule.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96705.o cameramodule/MAX96712cameramodule/CNvMMAX96712CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96759CameraModule.o cameramodule/MAX96712cameramodule/CNvMMAX96712_96717CameraModule.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96717.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_96759.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_TPGSerializer.o cameramodule/MAX96712cameramodule/CNvMTransportLink_Max96712_9295.o cameramodule/common/TransportLinkIF/CNvMTransportLink.o cameramodule/common/EEPROMIF/CNvMEEPROM.o cameramodule/common/SerializerIF/CNvMSerializer.o cameramodule/common/SensorIF/CNvMSensor.o cameramodule/common/PMICIF/CNvMPMIC.o devices/MAX9295ASerializerDriver/CNvMMax9295.o devices/MAX9295ASerializerDriver/cdi_max9295.o devices/MAX96705SerializerDriver/CNvMMax96705.o devices/MAX96705SerializerDriver/cdi_max96705.o devices/MAX96712DeserializerDriver/CNvMMax96712.o devices/MAX96712DeserializerDriver/cdi_max96712.o devices/MAX96717FSerializerDriver/CNvMMax96717F.o devices/MAX96717FSerializerDriver/cdi_max96717f.o devices/MAX96759SerializerDriver/CNvMMax96759.o devices/MAX96759SerializerDriver/cdi_max96759.o devices/N24C64EEPROMDriver/cdi_n24c64.o devices/TPGSerializerDriver/CNvMTPGSerializer.o devices/TPGSerializerDriver/cdi_tpgserializer.o devices/TPGSerializerDriver/TPGSensorSerializerUtility.o ../../utils/log_utils.o ../../utils/thread_utils.o cameramodule/common/utils/pwr_utils_stub.o -lnvos -lnvsipl_devblk_cdi -lnvsipl_devblk_ddi -lnvsipl_devblk_crypto -lstdc++ -ldl -lpthread -L/drive/drive-linux/lib-target -Wl,--no-undefined -Ldevices/MAX20087Driver -lnvsipl_devblk_campwr_max20087
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/DS90UB9724cameramodule/ds90ub9724_971tpg/CNvMDS90UB9724_971_TPG.o cameramodule/DS90UB9724cameramodule/ds90ub9724_971tpg/CNvMDS90UB9724_971_TPG.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o cameramodule/DS90UB9724cameramodule/ds90ub9724_971tpg/cdi_ds90ub971_tpg.o cameramodule/DS90UB9724cameramodule/ds90ub9724_971tpg/cdi_ds90ub971_tpg.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/DS90UB9724cameramodule/CNvMTransportLink_DS90UB9724_971.o cameramodule/DS90UB9724cameramodule/CNvMTransportLink_DS90UB9724_971.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/DS90UB9724cameramodule/CNvMDS90UB9724CameraModule.o cameramodule/DS90UB9724cameramodule/CNvMDS90UB9724CameraModule.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o cameramodule/DS90UB9724cameramodule/CNvMDS90UB9724_971CameraModule.o cameramodule/DS90UB9724cameramodule/CNvMDS90UB9724_971CameraModule.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/DS90UB971SerializerDriver/CNvMDS90UB971.o devices/DS90UB971SerializerDriver/CNvMDS90UB971.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/DS90UB971SerializerDriver/cdi_ds90ub971.o devices/DS90UB971SerializerDriver/cdi_ds90ub971.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include/nvmedia_6x -I. -I./common -I./common/include -I./common/utils -I./common/core -I./common/ddi -I./common/trace -I./cameramodule -I./cameramodule/common -I./cameramodule/common/utils -I../query/src -I./devices -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -std=c++14 -fexceptions -frtti -fPIC -c -o devices/DS90UB9724DeserializerDriver/CNvMDS90UB9724.o devices/DS90UB9724DeserializerDriver/CNvMDS90UB9724.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-gcc -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -D_FILE_OFFSET_BITS=64 -fPIC -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I. -I../ -I../../utils -Idevices/DS90UB971SerializerDriver -Idevices/DS90UB9724DeserializerDriver -Idevices/MAX20087Driver -Idevices/MAX9295ASerializerDriver -Idevices/MAX96705SerializerDriver -Idevices/MAX96712DeserializerDriver -Idevices/MAX96717FSerializerDriver -Idevices/MAX96759SerializerDriver -Idevices/N24C64EEPROMDriver -Idevices/TPGSerializerDriver -I./common/utils -I./common/crypto/include -I/drive/drive-linux/include/nvmedia_6x -c -o devices/DS90UB9724DeserializerDriver/cdi_ds90ub9724.o devices/DS90UB9724DeserializerDriver/cdi_ds90ub9724.c
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -shared -L/drive/drive-linux/lib-target -Wl,--no-undefined -o cameramodule/DS90UB9724cameramodule/ds90ub9724_971tpg/libnvsipl_devblk_drv_ds90ub9724_971tpg.so cameramodule/DS90UB9724cameramodule/ds90ub9724_971tpg/CNvMDS90UB9724_971_TPG.o cameramodule/DS90UB9724cameramodule/ds90ub9724_971tpg/cdi_ds90ub971_tpg.o cameramodule/DS90UB9724cameramodule/CNvMTransportLink_DS90UB9724_971.o cameramodule/DS90UB9724cameramodule/CNvMDS90UB9724CameraModule.o cameramodule/DS90UB9724cameramodule/CNvMDS90UB9724_971CameraModule.o cameramodule/common/TransportLinkIF/CNvMTransportLink.o cameramodule/common/EEPROMIF/CNvMEEPROM.o cameramodule/common/SerializerIF/CNvMSerializer.o cameramodule/common/SensorIF/CNvMSensor.o cameramodule/common/PMICIF/CNvMPMIC.o devices/DS90UB971SerializerDriver/CNvMDS90UB971.o devices/DS90UB971SerializerDriver/cdi_ds90ub971.o devices/DS90UB9724DeserializerDriver/CNvMDS90UB9724.o devices/DS90UB9724DeserializerDriver/cdi_ds90ub9724.o ../../utils/log_utils.o ../../utils/thread_utils.o cameramodule/common/utils/pwr_utils_stub.o -lnvos -lnvsipl_devblk_cdi -lnvsipl_devblk_ddi -lnvsipl_devblk_crypto -lstdc++ -ldl -lpthread -L/drive/drive-linux/lib-target -Wl,--no-undefined -Ldevices/MAX20087Driver -lnvsipl_devblk_campwr_max20087
make[2]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl/devblk'
test ! -r test/camera/Makefile || make -C test/camera
make[2]: Entering directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/camera'
../../../../../make/nvdefs.mk:166: Defaulting NV_WINSYS to x11; legal values are: egldevice wayland x11 direct-to-display
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -std=c++14 -fexceptions -frtti -fPIC -I../../../../../include/nvmedia_6x -I../plugin -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -D_POSIX_C_SOURCE=200112L -c -o CUtils.o CUtils.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -std=c++14 -fexceptions -frtti -fPIC -I../../../../../include/nvmedia_6x -I../plugin -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -D_POSIX_C_SOURCE=200112L -c -o main.o main.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -std=c++14 -fexceptions -frtti -fPIC -I../../../../../include/nvmedia_6x -I../plugin -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -D_POSIX_C_SOURCE=200112L -c -o CComposite.o CComposite.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -std=c++14 -fexceptions -frtti -fPIC -I../../../../../include/nvmedia_6x -I../plugin -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -D_POSIX_C_SOURCE=200112L -c -o CCompositeNvSci.o CCompositeNvSci.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -Os -O2 -fomit-frame-pointer -finline-functions -finline-limit=300 -fgcse-after-reload -fno-strict-aliasing -Wall -mharden-sls=all -Wcast-align -std=c++14 -fexceptions -frtti -fPIC -I../../../../../include/nvmedia_6x -I../plugin -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -D_POSIX_C_SOURCE=200112L -c -o CNvWfd.o CNvWfd.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -L/drive/drive-linux/lib-target -L/drive/drive-linux/lib-target/x11 -Wl,-rpath-link=/drive/drive-linux/lib-target -Wl,-rpath-link=/drive/drive-linux/lib-target/x11 -L/drive/drive-linux/targetfs/lib -L/drive/drive-linux/targetfs/usr/lib -L/drive/drive-linux/targetfs/usr/lib/tls -Xlinker -rpath-link -Xlinker /drive/drive-linux/targetfs/lib -Xlinker -rpath-link -Xlinker /drive/drive-linux/targetfs/usr/lib -Xlinker -rpath-link -Xlinker /drive/drive-linux/targetfs/usr/lib/tls -Wl,--dynamic-linker=/lib/ld-linux-aarch64.so.1 -o nvsipl_camera CUtils.o main.o CComposite.o CCompositeNvSci.o CNvWfd.o -L../../lib -lnvsipl_sampleplugin -lnvsipl_query -lnvsipl -L../utils/lib/ -lnvscibuf -lnvscisync -lnvscistream -lpthread -ldl -lrt -lstdc++ -ltegrawfd -lnvmedia2d
make[2]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/camera'
test ! -r test/sample/Makefile || make -C test/sample
make[2]: Entering directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/sample'
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I./platform -I../../../../../include/nvmedia_6x -std=c++14 -fexceptions -frtti -fPIC -c -o CImageManager.o CImageManager.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I./platform -I../../../../../include/nvmedia_6x -std=c++14 -fexceptions -frtti -fPIC -c -o CUtils.o CUtils.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -I./platform -I../../../../../include/nvmedia_6x -std=c++14 -fexceptions -frtti -fPIC -c -o main.o main.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -L/drive/drive-linux/lib-target -L/drive/drive-linux/lib-target/x11 -Wl,-rpath-link=/drive/drive-linux/lib-target -Wl,-rpath-link=/drive/drive-linux/lib-target/x11 -L/drive/drive-linux/targetfs/lib -L/drive/drive-linux/targetfs/usr/lib -L/drive/drive-linux/targetfs/usr/lib/tls -Xlinker -rpath-link -Xlinker /drive/drive-linux/targetfs/lib -Xlinker -rpath-link -Xlinker /drive/drive-linux/targetfs/usr/lib -Xlinker -rpath-link -Xlinker /drive/drive-linux/targetfs/usr/lib/tls -Wl,--dynamic-linker=/lib/ld-linux-aarch64.so.1 -o nvsipl_sample CImageManager.o CUtils.o main.o -lnvsipl -lnvscibuf -lnvscisync -lpthread
make[2]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/sample'
test ! -r test/plugin/Makefile || make -C test/plugin
make[2]: Entering directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/plugin'
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -DX11 -DVK_USE_PLATFORM_XLIB_KHR -I/drive/drive-linux/include -I/usr/local/cuda-11.4/targets/aarch64-linux/include -DWIN_INTERFACE_CUSTOM -D_POSIX_C_SOURCE=200112L -I. -I../../include -I../../query/include -I../utils/include/ -fpic -c -o CSamplePlugin.o CSamplePlugin.cpp
/drive/toolchains/aarch64--glibc--stable-2022.03-1//bin/aarch64-buildroot-linux-gnu-g++ -shared -L/drive/drive-linux/lib-target -Wl,--no-undefined -o libnvsipl_sampleplugin.so CSamplePlugin.o -lpthread -ldl -lrt -lstdc++ -L/drive/drive-linux/lib-target -Wl,--no-undefined
make[2]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl/test/plugin'
make[1]: Leaving directory '/drive/drive-linux/samples/nvmedia/nvsipl'
Hi @SivaRamaKrishnaNV So to clarify, on docker I can only build but to run i need the target. Right? So to make my changes i can modify the sample and try building. For testing run on target.
Thanks for the clarification.
Dear @jishnuw ,
Yes you can build on docker and needs to run on target
system
Closed
September 14, 2023, 2:30am
8
