I check the sensor extensions ( Range Based Sensor Simulation [omni.isaac.range_sensor] — isaac_sim 2023.1.1-rc.8 documentation (nvidia.com)), find that the omni.isaac.range_sensor.LidarSensorInterface.get_intensity_data() can get the point cloud intensity, but the intensity value is either 255 or 0, it is because Physx lidar cannot output the reflection intensity of point clouds at all?
Hey,
I built a ros2 package for the same requirement. Here is the Link.
Hope it supports your project!!
Related topics
| Publish ros2 message PointCloud2 with intensity data in isaac sim4.0 | 12 | 684 | August 22, 2025 | |
| Pointcloud configuration options (intensity, noise, pointcloud structure) for Isaac Sim and ROS Interface | 7 | 1100 | June 11, 2025 | |
| Intensity data PointCloud2 | 9 | 2177 | February 22, 2024 | |
| Ros2 publish point cloud excluding intensity information | 0 | 208 | July 4, 2024 | |
| RTX Lidar PointCloud 3D: How to set a custom intensity on objects? Changing the material properties have no effect | 9 | 457 | October 3, 2025 | |
| Intensities are not published from ROS1 Publish Point Cloud node | 4 | 151 | May 16, 2025 | |
| PhysX Lidar sensor to generate the semantic point cloud | 0 | 319 | January 1, 2024 | |
| Use PhysX Lidar to generate semantic point cloud data | 1 | 293 | August 12, 2024 | |
| Get_intensity_data() only return 255 or 0 in ultrasonic sensor | 1 | 89 | January 20, 2025 | |
| How to publish PhysX Lidar topic include x y z intensity ring timestap | 2 | 93 | August 15, 2025 |
