Hi Jeff,
You can open the launcher log by pasting the following line in the run dialog box: %userprofile%\.nvidia-omniverse\logs\launcher.log
Press Enter and search for the last [error] line.
Edit: You can also try if running the launcher with administrator rights does the trick.
And/or try if deleting the config directory in %userprofile%\.nvidia-omniverse\ helps.
[2021-12-11 20:25:14.949] [error] Error: Failed to open
[2021-12-11 20:25:15.635] [info] Login URL opened.
[2021-12-11 20:25:15.644] [error] Error: Failed to open
[2021-12-11 20:25:15.645] [error] Error occurred in handler for ‘log-in’: Error: Failed to open
[2021-12-11 20:25:15.645] [error] Error: Failed to open
[2021-12-11 20:25:16.004] [info] Login URL opened.
[2021-12-11 20:25:16.012] [error] Error: Failed to open
[2021-12-11 20:25:16.012] [error] Error occurred in handler for ‘log-in’: Error: Failed to open
[2021-12-11 20:25:16.013] [error] Error: Failed to open
[2021-12-12 03:15:43.461] [error] Error happened during the update: Error: net::ERR_FAILED
at SimpleURLLoaderWrapper. (electron/js2c/browser_init.js:105:6497)
at SimpleURLLoaderWrapper.emit (events.js:315:20)
[2021-12-11 20:16:23.456] [debug] Reset current installer.
[2021-12-11 20:16:23.469] [info] Can’t access the C:\Users\ME.nvidia-omniverse\config\privacy.toml file: ENOENT: no such file or directory, access ‘C:\Users\ME.nvidia-omniverse\config\privacy.toml’
[2021-12-11 20:16:23.531] [error] (node:16140) electron: The default of contextIsolation is deprecated and will be changing from false to true in a future release of Electron. See [Discussion] Changing the defaults for nodeIntegration and contextIsolation to improve the default security posture of Electron applications · Issue #23506 · electron/electron · GitHub for more information
[2021-12-11 20:16:23.730] [info] Requesting the feature list for en…
[2021-12-11 20:16:23.791] [info] Running production web server.
[2021-12-11 20:16:23.794] [info] HTTP endpoints listening at http://localhost:33480
[2021-12-11 20:16:24.728] [info] Enabled features for en: { bugReports: false }
[2021-12-11 20:16:47.001] [info] Login URL opened.
2021-12-11 20:16:47.025] [error] Error: Failed to open
[2021-12-11 20:16:47.026] [error] Error occurred in handler for ‘log-in’: Error: Failed to open
[2021-12-11 20:16:47.026] [error] Error: Failed to open
Probably a corrupted file.
I’ve created a batch file which removes all Omniverse related files. Omniverse Cleaner
Run it and reinstall Omniverse.
If it still doesn’t work, try running the batch file and the installer with administrator privileges.
@Jeff_Costello - if i am reading this chain correctly, you ran a cleanup tool posed by a user. The link i sent you is to the NVIDIA site with a tool created by us.
